engagment problems
Mindslayer
323
May 17, 2002
Charlotte, North Carolina
My problem is my car can go into any gear when the clutch is in and when the car is off. But when I start the car. It won't go into any gear. And if it's in a gear you can't pull it out ... what could be the problem.In other words what's now when bad.
Clutch master or slave problem. Change them both should be under 75$ easy job do it all yourself. then bleed and u should be good to go
