Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 08-13-2002, 10:27 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: kidd gs-t is an unknown
Angry Help!! Tranny Messed Up...again!!
hey, i was driving home, then i decided to have a lil fun on the freeway, so i stopeed at a toll, decided to accelerate hard, i shift around 5k, which is like above average, and for some reason miss 3rd, then when it catches, the rpms jump past redline, so i disegage it out of gear of course, and drive normal after the rpms settled. However as i drive i feel the clutch getting weaker, and when i got home i checked if it was leaking and as i was backing up my car the clutch juss dies. this happned to me b4 and i had to get my car towed, then after the guy who "fixed" it he told me that i had bad hydrolyics and it leaked tranni fluid. I had my tranni fixed by bm tranni again becuz my 2nd gear was grinding(as you can c in my profile). I know my tranni is good ### it was juss fixed, and the bad hyrdolics was cauzed by me being foolish enuff to drive it afterwards even though the clutch was dying (stupid me!!). Plus the alck of tranni fluid i nthe car. Luckily i made it home. What is the problem? I know it's just leaking tranni fluid but what do i look for, what do i fix?Please help, i just got my car fixed and it f-d up again.
Update
I just examaned where the leak was coming from, it's coming from this plastic that runs from the 2 screw in the front where u jack it , i'm trying to find the proper name for it at first i thought the tranni was leaking, then i thoguht either the master or slave cylinder was leaking, i have pretty much narrowed it down to there,
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11247301 seconds (62.21% PHP - 37.79% MySQL) with 9 queries
