Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 08-11-2002, 07:22 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: WonkoTheSane is an unknown
Clutch/tranny problems, About to destroy the car (no, not the clutch, ME!)
(crossposted, mods, feel free tor smite me or move my post as nessicary)
Heyo, the guys over at dsmtalk.com didn't seem to be able to help me, nor did anyone who lives around me or anyone i know... Here's my problem, in november of last year, the clutch in my car (92 eclipse 1.8) went out.. no big deal, i figured it was a simple two hour job... (who hasn't changed a clutch or 10?). Well, 9 months later, this thing has not run dependably... the longest i had it running was two weeks...
Here's what it does. When I try to shift, it won't let me into gear, grinding if i try first or reverse.. If i start the car in gear, i tries to move the car in the respective direction, but won't let me shift out of gear.
What i've done: I've had the tranny out at least 5 times, i've changed every moving component of the clutch system (see below), and I've bled through at least two quarts (###### more) of break fluid.
What i changed/Fixed: Flywheel, Clutch Disc, Pressure Plate, Throwout Bearing, Fork, Pivot that the fork sits on, Slave Cylinder, Master Cylinder, and i've had the pedals welded in place (on the shaft), to make sure there was no play in the system.
I've done everything short of throwing 500 dollars at a mechanic and saying "Fix this POS before i take a sledgehammer to it!". and that's only because i don't have 500 dollars to do that with.. I was wondering if anyone had ANY good ideas or feedback about this?
Sorry about the length of my post, i just wanted to make sure that i covered all my bases, feel free to ask any questions about procedure or anything like that.
Thanks for any comments, suggestions in advance!
~Aaron
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09925199 seconds (66.98% PHP - 33.02% MySQL) with 9 queries
