Xfer case problem......?????
GBabyTSI
102
Dec 1, 2002
Lake Charles, Louisiana
ok my problem is that i had some fluid leaking and didn't know where it was coming from and it was a bad leak. i had to pull my tranny already so i was gonna just check it out when i was doing that well i drain the 22 spline Xfer case and take it off it still had a little in there but i turned it upside (side the drive shaft goes in to ) and the rest of the fluid kinda just poured out of that end has anyone else ever had this problem and what could cause it to do that a bad seal any info would be nice thanks..:thumb:
Gary
There is a recall on the transfer cases due to them leaking oil. The leaking can cause the case to be inadequately lubricated and can cause lock up. If that is your problem the problem has to be fixed for free by the dealer.
