Help Broken Parts
95EclipseGSX
34
Dec 12, 2002
Does anyone know how to fix the rubber parts on the ends of the steering where it meets with the knuckle??? Also the rubber joint where it meets the and top of the knuckle??? There rubber parts that keep the joints lubed under movement they broke easy when I stuck the fork between the joints to remove them.. Is this a cheap and easy fix ill send pix to replyers this damn thing wont let me attach the file because its to big. thanks for the feedback..
You can get new boots at the parts store. They usually die when you hit them with a pickle fork. You need to split the joint from the knuckle to replace them, not a big deal if you have air power, otherwise it kinda sucks.
