Xphile1999
- 40
- Apr 15, 2003
90 Talon TSI,
Put a new transmition in it, (old one was locked up). Bolts up just fine, but the TOB cannot press the pressure plate far enough before the fork presses against the fork window. We have taken every measurment possible, everything is the same! The Fork pivot point is cast to the housing so we cant shim it.
It didn't work w/ the same exact clutch....the clutch wasn't even touched.
We decided to put in a ACT 2600 while we where having problems to see if it would clear up the problem.
No such luck! Any Ideas?
-X
-X
. What torque did you use on the pressure plate bolts?
