Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 07-31-2002, 05:49 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: serviceguy is an unknown
Question 1G FWD Equal Length Driveshaft mod.
I've recently installed the left driveshaft from a 1G AWD on my FWD as specified on the Equal Length Driveshaft page (I think it is not available on line anymore). It wasn't easy since I am not a mechanic and I could not rise the car that much but it works. I noticed some improvement (that doesn't give my car the traction of an AWD but made it a lot better) and I just wanted to know if this mod is somehow common or, being most of the hardcore DSMers riding an AWD, just unheard of.
Leo
'91 Eclipse GS-T
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 08-09-2002, 09:52 PM   #2 (permalink)
Proven Member
Region: Southeast
Reputation: indy1979 is an unknown
ummm, how can the drive shafts be equal legnth? I'm confused. the diff is on the right side so the left one has to be longer to get to the hub. right? please explain.
Sam
Offline
Old 08-10-2002, 07:17 AM   #3 (permalink)
Proven Member
Region: Eastern Canada
Reputation: HITNRUN is an unknown
You used the intermediat shaft of you AWD right? All you do is take the intermediat shaft and the axle of the AWD and put it on the FWD. The intermediat shaft should be able to bolt on to a FWD car.
Offline
Old 08-13-2002, 03:03 PM   #4 (permalink)
Proven Member
Reputation: ECI Multi is an unknown
serviceguy, The axle bolted right in or you had to mess with it?? Cause I wanna do this to my car I have the axle already I just havent put it in yet
Offline
Old 08-13-2002, 05:16 PM   #5 (permalink)
Proven Member
Region: Southeast
ok, not up on AWD names. the intermediate shaft, I'm guessing is the front half of the axel going back to the rear diff, correct?
Sam
Offline
Old 08-13-2002, 05:38 PM   #6 (permalink)
Proven Member
The Intermediat shaft is just a shaft that runs from the transmission then attaches to the left front axle. It makes both front axles the same length. The picture shows the L/F axle then the purple circle shows the intermediat shaft bearing which bolts to the block. Then to the right of that is the intermediat shaft.
Offline
Old 08-13-2002, 05:46 PM   #7 (permalink)
Proven Member
Region: Southeast
ahhhh, i see said the blind man to the deaf boy with a three legged dog.
Sam
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12626696 seconds (74.97% PHP - 25.03% MySQL) with 9 queries
