differences between 94 and 95 tranny
Originally posted by nine5raptor
can I use a 94 tranny in my 95?
Yes it will bolt right up, but you will need to bend the shifter arm and adjust the shifter bracket a bit. As for transmission mounts, you will need to take out 2g main mount plate on put on 1g tranny. The 2g rear mount plate can not be used on 1g. For the 2g starter dust shield, you will need to enlarge the two holes. You will have to use 2g clutch slave. This is all I can think off. Good luck.
the front mount is attached to the block on 94's (I think) and the tranny on 95's (I know this one for sure) isn't it (i've been doing some research on it, but I still haven't found a complete answer)?
soory I don't quite follow you here. There's no mount on the 1g tranny attached to the block. It only has one mount and it's attached to the fender well wall .
2g tranny has two mounts. One is attached to the fender well wall like the 1g and another is attached to the beam below the steering rack.
the 1Gs have the front engine mount on the block instead of on the tranny like the 2Gs i think
