Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 05-05-2008, 10:31 PM   #1 (permalink)
Proven Member
DSMcamaro's Avatar
Region: Midwest
Classifieds Rating: (2)
Reputation: DSMcamaro is extremely helpful and trustworthyDSMcamaro is extremely helpful and trustworthy
90 transmission in a 91-94 WILL WORK!
Well after blowing my stock transmission in my 91, I finally went ahead and decided to find out if a 90 tranny would fit in a 91 without changing the shifter cables/shifter etc. It went perfect and now my shifter actually has a shorter throw than before. I used the 91 cable bracket, 91 cables, and the 91 shifter! Just thought I would let people know since I've always read that you need to swap everything. However, I would not recommend going the other way and putting a 91+ into a 90. I think this would cause issues, but I've never personally tried it.
If you want to see my blown tranny....
http://www.dsmtuners.com/forums/hang...cs-inside.html
PS: for a 93-94 you would have to get the smaller diameter cv-shafts.
PPS: this is a FWD turbo car, I assume AWD would be similar but have not tested it.
____________________________
-Paul
1991 FWD 14b
Offline
Related Auctions
Sponsored Links
Old 05-15-2008, 09:57 PM   #2 (permalink)
Proven Member
Region: Southwest
Classifieds Rating: (1)
Reputation: TheBoosted96GST is an unknown
my '90 has a 91 Trans in it now... Shift cables,shift assembly (shifter), and trans cable bracket needs to be for 91. Shifts like a champ, I've done the swap from both ways in the past and ya the 90 trans into a 91 is easier and shorter throw, but it's not very difficult to swap a new shift assembly + cables in for the 90.
Offline
Old 05-16-2008, 02:24 AM   #3 (permalink)
Proven Member
RoasT BeeF's Avatar
Region: Rocky Mountain
Classifieds Rating: (9)
Reputation: RoasT BeeF is extremely helpful and trustworthyRoasT BeeF is extremely helpful and trustworthy
I put a 91 trans in my 90 car without changing anything. Problem you will run into is the car wont go into gear, this is because of the difference in the shifter arms between the transmissions. The 90 cables will not push the arm far enough forward to put the car in gear. All you need to do is drill a hole in the shifter arm next to the stock mounting post and use a nut and bolt to connect the shifter cable to the arm. This enables the cable to push the arm in gear. Everything else is the same.
Brent
Offline
Old 05-16-2008, 10:11 AM   #4 (permalink)
Proven Member
Region: Tri State
Classifieds Rating: (3)
Reputation: 90laserRSfwd is an unknown
I agree and 2nd all this stuff, a 90 trans can go into a 91 car. but 91 trans in a 90 car is a no go.... (without changing shifter cables, shifter base, etc.)
e85 = Motivational Relocation
~ Jayson ~
Offline
Old 05-16-2008, 10:44 AM   #5 (permalink)
Proven Member
spoonman's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: spoonman is more helpful than not
I have a 1992 FWD TURBO transmission in my car with a 90 shifter, cable, and brackets. With very little adjustment the car goes into all gears perfectly. My block and motor mounts are from a N/T car though, so the engine does sit a little closer to the fire wall.
Morgan, bought car for $300.
Offline
[posts] Reply With Quote
Old 05-17-2008, 06:02 PM   #6 (permalink)
Ben
Proven Member
Region: Gulf Coast
Reputation: Ben is an unknown
This is a huge delima I'm having right now. I just got my trans from Jacks and I asked for the wrong shaft shaft length. I asked for the shorter one(90 I think) and I have a 91. I would go ahead and put it in, but I want to make sure I won't void the warranty my doing so.
I had already pulled my trans out, then noticed the arm. Now my eclipse is tying up my lift at work.
I want to hear from Jacks if it's ok to put in or not.
06 evo IX
91 GSX
Offline
Old 05-21-2008, 05:40 PM   #7 (permalink)
Ben
Proven Member
Region: Gulf Coast
ok, this combination does NOT work....
91 car and shifter
90 cables and mounting bracket.
I don't know which is which for the shift arm that bolts to the trans. I have a long one and a short one. I used the short one and side to side is fine.
the forward backward motion at the shifter is no bueno. The cable is too short and so the natural position of the shifter is already to the rear of the car. So when I try and put it in (all the down gears) 2nd,4th and revers, it hits the stop before it makes it all the way in the gear.
06 evo IX
91 GSX
Offline
Old 05-21-2008, 05:44 PM   #8 (permalink)
Proven Member
RoasT BeeF's Avatar
Did you read my post? Take a picture of the shifter arms on the tranny and Ill show you exactly what to do if you dont understand my post.
Brent
Offline
Old 05-21-2008, 09:34 PM   #9 (permalink)
Ben
Proven Member
Region: Gulf Coast
I'm not looking to modify a brand new transmission that's under warranty unless aproved by Jack.
A buddy of mine I know has a 90 shifter assembly he was about to throw away. I just have to drive a little over an hour to get it. Looks like I'm going to New Mexico tomorrow.
06 evo IX
91 GSX
Offline
Old 05-21-2008, 11:09 PM   #10 (permalink)
Proven Member
DSMcamaro's Avatar
Region: Midwest
Quote:
91 car and shifter
Did you try adjusting the cables on the shifter?
-Paul
1991 FWD 14b
Offline
Old 05-22-2008, 09:53 AM   #11 (permalink)
Ben
Proven Member
Region: Gulf Coast
There's no adjustment on that cable. Just the side to side cable has an adjustment.
06 evo IX
91 GSX
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help with a 90' Transmission in a 94' GoldÐiamond Drivetrain Tech 35 09-30-2006 09:15 AM
90 transmission vs. 91 transmission TsssiAWD Problem Diagnosis 8 09-18-2005 08:03 PM
90-91 body kit on 92-94, how much work? ucancallmedebo Appearance/Interior/Exterior 9 02-27-2005 09:35 AM
90 tsi, will 91-94 tb work? BlackTopPat Bolt-on Tech 4 02-01-2005 04:59 PM
Will a 90 iac motor work with a 91-94 tb? 92tsifwd Bolt-on Tech 6 01-30-2005 02:56 PM
Page generated in 0.17027211 seconds (80.65% PHP - 19.35% MySQL) with 10 queries
