Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 03-08-2008, 04:15 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: gmule is an unknown
1G-specific open circuted kickdown servo
Hi everyone,
Search has got me this far but I need a little help with some diagnoses,
Vehicle: 1991 Eagle Talon AWD TSI no mods bone stock. It is a my daily driver.
Problem: The transmission only has reverse and second. I searchead and found out how to get the codes.
I have a a code 14 and a code 21
Code 14 is for TPS adjusted properly. I have folowed the procedure to check and adjust this using my Haynes manual and everything checks out correctly
Code 21 tells me that there is for an open - shorted kickdown servo.
How can I test this portion? I have checked for lose / broken wires and a the connector plug.
Is this something that is as simple as a bad sensor or switch?
Any help would be greatly appreciated.
Greg
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Kickdown servo shorting out! blackbyrd Automatic Tranny 25 03-05-2008 07:39 AM
Kickdown Servo Switch Removal? HELP!!!! AutomagicGSX Newbie Forum 1 01-06-2007 08:45 PM
kickdown servo adjustment 92eagleTSI Automatic Tranny 5 08-09-2006 11:18 AM
IAC Servo MitchTSIAWD Newbie Forum 1 06-09-2004 06:33 AM
Idle surge problem (ISC Servo) adgrey Newbie Forum 1 05-22-2004 05:54 PM
Page generated in 0.09934902 seconds (67.34% PHP - 32.66% MySQL) with 10 queries
