Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 03-01-2008, 11:23 AM   #1 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (0)
Reputation: kre8ive_kustomz is an unknown
2G-specific Freshly rebuilt 5 speed won't shift into reverse
Okay, so heres the deal, I just rebuilt my awd trans because when i bought the car 4th & reverse didnt work. The 3&4/5&R interlock was sloppy so all those issues were fixed. when testing the gears with the case apart it would go fully into all gears and now back in the car everything but reverse works. I pulled the reverse sensor on the top of the trans and it looks like the notch lines up perfect to the ball on the sensor. I checked all linkage, the shift cable has full range so thats not the problem. I replaced the slave cylinder and used an extended rod, that didnt work so i tried the stock rod, still the same thing. Is there something else in the hydraulic clutch system that would cause only reverse not to work? it will start to engage but pops out almost immediately. Also, if i hold the brake while letting the clutch out in reverse the car will simply stay in gear and die, if i bring it to the dying point and let of the brake it pops out of gear as soon as the car starts rolling.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Freshly Rebuilt 1G Having Issues. DallasN2O Problem Diagnosis 15 08-14-2007 01:14 PM
Oil coming from downpipe on freshly rebuilt motor bling5tatus Newbie Forum 8 06-26-2007 03:45 PM
rebuilt my transa now it stays in reverse brandonzero0 Newbie Forum 1 05-18-2007 08:54 PM
Freshly Rebuilt :) Now a few Questions 2GSOCAL Newbie Forum 2 05-16-2007 02:19 PM
Very notchy freshly rebuilt transmission robs90tsi Newbie Forum 15 02-11-2007 03:57 AM
Page generated in 0.09278893 seconds (62.88% PHP - 37.12% MySQL) with 10 queries
