Quote:
Originally Posted by Slo2gen
Thats what I am asking, can I buy the axels for a 1g that are 4 bolt and replace my 3 bolt diff with the 2g 4 bolt and use the 1g 4 bolt axels. Axels aren't cheap so I don't want to buy them if they are not going to work.
If you search the forums the answer is already there :-)
1G and 2G axles are totslly different, there is no way they can ever be adapted to cross generations.
The only axles that will work with a 2G LSD are 2G LSD axles - the inboard joint is different between LSD and non-LSD axles; further, the left LSD inboard joint is different from the right LSD inboard joint (and both are different from non-LSD joints), so you must get one of each.
Not only but also, the axle shafts are different between LSD and non-LSD axles.
The ONLY part that interchanges between 2G LSD and non-LSD rear axles is the outboard joint - but even then, ABS cars have an ABS cog pressed on that non-ABS cars do not (and the lip isn't there on non-ABS axles to accept the ABS ring).
In a nutshell, it really isn't as simple as it sounds !
Charles
