Psycron
- 217
- 1
- Jul 29, 2002
Farmington Hills,
Michigan
I didn't float any valves or anything but something like the high pitched sound of small metal parts breaking *plink, plunk*. Was on the fwy and went to downshift to 4th quickly but she missed and went to 2nd gear, I couldn't catch it fast enough to save the damage it caused. I had to drive the car to a trans shop and I had to force the car into 2nd to get it going, once trying real hard on a slight incline and now the gear just grinds while the car isn't moving. What does that mean? I took it to a place called Multistate transmission who does reputable and honest work; from what they can see it will be 980 bucks to fix the clutch that is broken, that's excluding the trans. My question is this: What is the possible damage to the trans? I couldn't even force it into 1st gear. If I get the work done may the car be driveable? I have given all the info I can think of...let me know what else. Thanks for any advise you guys can give me on this, if I don't get it fixed I'll be waiting another week for a paycheck.
. Should've gotten in towed. I can shift without the clutch but I found it only works if you:
