Slow99x
- 348
- 1
- Dec 19, 2002
Lake County,
Illinois
Have a weird problem and need to know if anyone else has had a similar situation and what the solution, if any, that you may have found. Long story short, I keep snapping the pivot on the shifter (where it attaches to the vertical portion). The part that I have snapped twice seems to be welded from the factory and it has broken on me twice and not even under stress at that time. I don't know if it's just me shifting too hard or there is a manufacturer defect (like we don't have enough of those already), or is it just a coincidence. If it helps my drivetrain mods are as follows: TRE stage 1 trans with a 4 spider center diff, Jun flywheel, metal shifter bushings (under the center console only), and a Greddy counterweight shift knob. I don't think that the shifter bushings are causing this but I would like to hear what someone else thinks.
