Ryan86
- 420
- 2
- Nov 16, 2002
Discovery Bay,
California
SBR 3500
Fidanza Flywheel with new friction plate
Braided SS clutch line
New master cylinder
New slave cylinder
System bled three times. No bubbles.
The biggest problem would be that it's grabbing right off the floor. Within the first 20min of driving the car, it's not that bad. But then after, it seems like the engagement point drops a little bit more (why??)...then it will grind going into reverse and is a pita to get into first. The master cylinder is adjusted out as far as it can go without getting any 2G "pump up". Also, the pedal won't go all the way to the floor. It stops about an inch before. The more the master is adjusted out, the farther away the pedal is from the floor when depressed. So basically, adjusting the master isn't doing anything for me. Why is this?
And when I'm decellerating, something vibrates...extremely loud. I can't really tell if it's coming from the tranny area or underneath me. Cruising around 3000RPM and 18-20in/hg I get the same vibration, but less severe. Also, if I start off slow in first or reverse, there is a ton of chatter and vibration...like my tranny and rear end are just gonna hop out. It already broke the plug for my reverse lights!
Annnd...this has happened about 4 times now: http://media.putfile.com/weird_noise . If I was gonna pull something outta my ass, I'd say it was the starter engaging randomly one outta thirty times I go WOT. WTF
So what's going on here?
New master cylinder
New slave cylinder
and putting a new fork and pivot ball in. I also added a 1.5mm washer under the pivot ball to give it a little extra breathing room. Everything looks great now. I know pulling the tranny again sucks but best of luck!
