Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 09-28-2005, 07:41 AM   #1 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: MNGSX is extremely helpful and trustworthyMNGSX is extremely helpful and trustworthy
The $18 clutch master cylinder rebuilt "mod"...
The master cylinder is a 5 minute rebuild and the kit costs around $18..
Carquest Clutch Master Kit M7386
Just remove the clutch res/bracket and master cylinder.
Unscrew the single slot head screw on the bottom in the middle of it length wise. Pull the o ring off the screw and throw it away..
Pull the end boot then the circlip and it will pull apart. Throwout the clip because there is a new one...
Keep the outer body (obvious), pushrod assembly (threaded) and the small screw.
The aluminum piston will get tossed...
Clean the old parts very well.. then lightly lube the new piston with brake fluid and gently install it.. Put the new o-ring on the screw and install it.. Then put a drop of grease (I used anti sieze because it stays put) on the ball end of the push rod.. Install the new clip then the new boot..
From there follow RRE's clutch adjustment page..
http://www.roadraceengineering.com/c...ywheeltech.htm
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09980893 seconds (62.35% PHP - 37.65% MySQL) with 9 queries
