Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 01-11-2005, 07:44 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Nos~4G63 is an unknown
Clutch/shifting woes
I recently got my car to shift great after much adjustment with shifter cables and the clutch pedal. A made a few run's from a 45mph roll sunday night and powershifted every gear with no problem's. Then I let the car cool down and attempted to do a couple dig run's. When I come out the hole on the 2step (5,500) I slip the clutch and it smell's pretty bad but hold's the power and when I shift to second it wont go into gear. And after letting off it is real notchy to go into any gear. Am I overheating the clutch? I don't know what else to do, I am going to fill the tranny with syncromesh and see if that helps but Im pretty sure it's a clutch issue.
Thanks for the help, tired of searching
____________________________
1989 Mirage 11.7
2006 EVORS 11.9
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.08966804 seconds (63.67% PHP - 36.33% MySQL) with 9 queries
