Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 01-10-2005, 11:15 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Chewie031 is an unknown
Had clutch release problems
had clutch release problems,, so i changed the slave cylinder and nothing so hopeing it wasnt the throwout bearing i replaced the clutch master cylinder and bingo that was the problem..
Question to anyone that may know..
I used ATF (automatic transmission fluid) instead of break fluid ### that was all i had on hand at the time to test the master cylinder and this seems to work fine..
the question is will this harm the master/slave or should i change to break fluid ..?
thanks in advance: Chuck
Offline
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09172702 seconds (61.91% PHP - 38.09% MySQL) with 9 queries
