Blindsey
- 243
- 1
- Sep 17, 2007
Holladay,
Utah
I've been working on car that runs poorly, the best way to describe it is the car sounds like it has cams, it doesn't though.
I did a compression test.
Cylinder 1 - 173
Cylinder 2 - 172
Cylinder 3 - 135
Cylinder 4 - 170
IIRC the manual says no more than a 20% variance in cylinders. Is this enough to cause a car to run poorly as if it has cams?
I've fixed all boost leaks, exhaust leaks and ensured the car is getting spark and fuel....
I've tried everything else, ha
Cylinder 1 - 173
Cylinder 2 - 172
Cylinder 3 - 135
Cylinder 4 - 170
