Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Cylinder Head & Short Block
Welcome to DSMtuners
Cylinder Head & Short Block: 4G63 cams, valvetrain, pistons, rods, stroker kits, 6-bolt swaps, hybrids, etc. Read this Forum's Strict Guidelines.
Reply
LinkBack   Thread Tools
Old 02-26-2006, 08:51 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
1sick91tsi's Avatar
Tech Posts: 135
Photos: 5
Classifieds Rating: 8
Reputation: 1sick91tsi is an unknown
Send a message via AIM to 1sick91tsi
intermiten starting!! help!!
to start out i just finished my rebuild, ok so my car will start and run great one second, the next it just wont start. it will start just fine several times in a row the next it just wont start, it cranks over but doesnt start, when it doesnt start the plugs are all bone dry, also the fuel pump never turns off when it wont start. like usually it will turn on the shut off after a few seconds but it just stays running. when the car starts the thing runs great no problems, idles great revs up great no problems. also the car was sitting for about say 8 months with a quater tank of gas so i put about 7 gallons of 116 in it. also when it wont start for me if i put some starting fluid in it it starts right up and runs great. if you need more info let me know here are my mods, 20g turbo, 2g throttle body elbow,full 3' magnaflow exhaust, test pipe,, dejontool intake pipe, magnecor plug wires, k&n air filter,2g maf, 550cc injectors, tmo stage 2 chip compenate for 550s, turbonetics extranal gate, 2g ports ex.manifold, halman boost controler, fluidyne rad, slim line fan, slow boy front mount with short route piping, crushed 1g bov, 2g o2 housing, s-afc, data logger, autometer egt gauge and boost gauge, 6-bolt, 2g pistons .20 over, clevitte bearings, arp rod and main and head bolts, no balance shafts, mitsu 4 piece head gasket. thanks for all the help guys!!!!!
View photos of this member's car
mark post as helpful recommend reputation points    Reply With Quote
Old 02-26-2006, 12:54 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
DSM Wiseman
Old Mitsu Tech's Avatar
Tech Posts: 1,217
Classifieds Rating: 1
Well, you just told us it's fuel related. Good. When it won't start, see if you have fuel pressure. It's a pain in the ass to do this, as you need the tool to put inline. Field test by loosening the filter upper nut to see if fuel sprays out.
If it sprays out, check the injector harness to see if it has 12 volts on it key on engine off. KOEO. If it does, put your test light on the positive post and crank the engine while probing the negative terminal of your injector harness. Winking light is good. Steady on or off means injector drive circuit is bad. Just find out if it's pressure related. Pump, or distribution related. Injectors or pcm.
Let us know.
Good Luck
____________________________
Rick
Old 02-26-2006, 02:38 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
1sick91tsi's Avatar
Tech Posts: 135
Photos: 5
ok, well it has fuel pressure, i took the return line off of the regulator and it sprayed out when i cranked the engine. now as far as checking the injectors, the one side is lit when i turn the key on, now are you saying when i crank it the other side should flicker? thanks so much for the help. oh also now, number 2 and 4 plugs are getting wet from cranking it and they all still have spark.
Old 02-26-2006, 03:09 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
GVR4592's Avatar
Tech Posts: 4,048
Photos: 1
Reputation: GVR4592 is a DSMtuners ExpertGVR4592 is a DSMtuners ExpertGVR4592 is a DSMtuners ExpertGVR4592 is a DSMtuners ExpertGVR4592 is a DSMtuners ExpertGVR4592 is a DSMtuners ExpertGVR4592 is a DSMtuners Expert
Check the caps in your ecu, I bet they leaked.
Old 02-26-2006, 03:12 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
DSM Wiseman
Tech Posts: 1,217
I agree with the cap thing. Hook your test light to the POSITIVE post of your battery. Probe the wire that does NOT have 12 volts to it. Have someone crank your engine to see if it flickers. No flicker or steady ON or OFF light will mean injector drive circuit which comes back to the PCM.
Just checking.
Good Luck
Rick
Old 02-27-2006, 08:43 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
1sick91tsi's Avatar
Tech Posts: 135
Photos: 5
ok well only number 2 and four cylinders are flickering, and it takes a couple cranks to get them to do it and its very faint. so i dropped my ecu off this morning and got it back already with new caps, they looked it over said that there wasent much corrision a little bit if that. tried it after that and still no better. so what do i need to do, get a new ecu or send it out to be fixed? Or does the injector drive circuit lie somewhere other then the ecu? thanks so much for the help guys
Old 02-28-2006, 07:14 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
1sick91tsi's Avatar
Tech Posts: 135
Photos: 5
anyone?!!
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.41%
111 Votes
2-5 - 43.60%
126 Votes
6-10 - 10.73%
31 Votes
11-15 - 2.77%
8 Votes
16-20 - 4.50%
13 Votes
Total Votes: 289
You may not vote on this poll.
» Online Users: 512
196 members and 316 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
