Maintenance and/or performance...???
vlaar
216
Oct 9, 2002
I didn't think it would be this hard to decide on what I want to do with my car this Christmas when I go home. I've got a '90 Talon TSi FWD that I want to work with. I'm 99% sure that the crank pulley has never been changed so this is one thing that I plan on doing. Here are some other things I want to do (can't do them all) soon: replace o2 sensor (mine is fine, but it's never been changed, shouldn't it be dead by now:confused: ), add powerslots with hawk brake pads/motul fluid or add just the pads and replace rubber brake lines with stainless steel ones, replace ISC motor (mine is going out), put in a B&M tranny LSD insert. I'll have about 300 dollars to spend. Any input? Thanks guys. Other suggestions? Info on the car below.
'90 Talon TSi FWD w/126K on the odometer
Mods: 16G, MAS mods w/K&N, 2.5 inch Dejon Upper I/C pipe, 3 inch Dejon intake, ACT 2100, 3 inch RNR racing turboback exhaust, Arospeed muffler, MBC (19 psi), rewired 190 Walbro, 180 degree thermo, Accel 300+ wires, NGK BPR7ES plugs, Symborski Kit, Speed-source shifter bushings, Pocketogger (m100 palm). All hoses/gaskets/timing belt/plugs/wires are basically new. As well as front halfshafts, etc.
Your setup and road to progression is very similar to mine. I too must put some attention to maintenance. Replacing the O2 sensor is a good start especially if you feel you are running overly rich. Of course an EGT would be a great source to see if you're running rich if not check for excess carbon on the exhaust pipe. Another good maintenance idea would be replacing the fuel filter, K&N makes a great filter for our vehicles that removes much of the restrictions caused by the factory paper filter. Good Luck.
-Extreme
