Chris95GST
- 224
- Aug 12, 2003
Hi, I just installed a MBC although I don't think it is related and have a problem with stalling now and before the install, although it now seems to now be more common. What happens is randomly when I put the clutch down my car stalls. It seems to happen more when it is cold and during braking. Also I seem to be running really rich because the 02 voltage was .105. Anyone have any ideas what might cause this? I am also not venting so it is not that. Thanks
I wish that were the case because then I would know that it is that.
It has happend around 5 times the past three months. All of the times I had put the clutch in and most I was braking as well. At fist I thought it was a loose battery cable so I tightned it and it went away for a month. Then it came back but I discovered I had a bad 02 sensor so I fixed that and it went away agian but now its back. I hope it has something to do with the MBC but it is to much like the other times and the car was running fine for awhile and all the hoses and stuff are still tight.
