BOV Return Ideas
GreenEagle
Nov 22, 2002
I just finished installing my Victory Performance FMIC kit, and I need to find something to use for a BOV return tube, as the stock one isn't close to working anymore. I thought of using a radiator hose, but don't know if I will be able to find one with exactly the right bend in it. I was trying to think of something more flexible that would just bend to whatever angle I need.
What is everyone else using with their aftermarket IC piping?
Just go to the auto store and show them your problem and look through their books to find a radiator hose that has the right amount of bend in it, you may have to cut it short but it will fit. I did the same thing with my greddy s and uicp and used a radiator hose from a 98 geo and it works awsome and is loud!!
Hope this helps
DO NOT VENT!! but i made myself a return tube from 1" silcone tube from Home Depo. I heated it up with a heat gun and slid it in place used some worm clams to hold it down and its fine. Although u can barly hear your BOV it works just fine.
-Dave
RACER-X, ur probably one of the few that can. But it is not recomended that you vent to the atmo. read up and do a search on venting. DON"T DO IT PERIOD.
thats not true.. i vented without one just fine with no problem.
well that my friend is not true. u run rich between gears which pulls timing like said above which equals lost horsepower. even though your car may seem to idle/run fine, its not. may not be much power loss at all but it def is too much for me. :dsm: every hp counts :thumb: :dsm:
