92tsiawd84
- 213
- Jan 6, 2003
Twin Cities,
Minnesota
I installed an Apexi AVC-R bc tonight but I haven't had much time to screw around with it. I probly am not going to mess with it until I get my boost creep fixed though. I was thinking tonight about the scramble setting. I was wondering if I could hook it up to my cruise control switch (like my stutterbox) and it let me build more boost before I launch. I was thinking of having my scramble setting around 25-30psi so I will hold ~17psi on the stutter box at the line. Then, when the clutch is released, it would jump back to my regular setting of 17psi and I will have full boost off the line. Could this work? If not, how would I build more boost on the line with my stutterbox.
). Boost is limited by engine load.. and with the clutch in.. load is virtually 0. If you were to slip the clutch a little and hold the brake.. could get more boost (at the expense of a clutch).
