profec b
its pretty easy, all you do is set the low and high settings using the little knobs. you hit the select button to switch from high to low. if you are getting some spike you can use the balance knob to help get that away. anything else that u wanna know?
thanks, i cant wait to get my stuff installed. i should have my boost/egt gauge, profec b, apex turbo timer, and my n1 installed.
wat results should i expect and wat do i need next (im still looking for a 1g bov but i cant find any)?
im not really down spending $98 dollars for a 1g bov from RRE and people i contact at dsmtrader either dont respond or dont have it anymore. im going to try to go to a junkyard hopefully i can find one
