Happy
Banned Member
- 404
- Feb 1, 2003
My motor !! Not questions like how do i take the motor out or how do i take the head off
I want a know if there is any secrets and some good combos out there to get some good hp!! Any one feel free to add something!!
So far this is what i got and am doing!! Oh ya my motor went lost all its compression!! So it's time for a rebuild.
Got a complete rebuild kit here is what it involves and instead of pistons and rings i am gettin them to through in a new oil pump in it s place instead..
Major Kit: contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30.
This kit should be fine dont you guys think?? Its from eagle!
Im goin with forged pistons but dont know what kind or should i bore it 10 over yet??
Putting in 3 generation lifters, and do u guys recomend getting a head job !!
Like port and polished and 3 angle valve job and shit like that??
What else should i do and get some extra hp??
Need all the help i can get thanks!!
Like port and polished and 3 angle valve job and shit like that??What else should i do and get some extra hp??
