jdmawd
Banned Member
- 3,318
- Mar 20, 2002
GreenBelt,
the time has come to knock the cob webs of this stock head i have in my basement, and send it out to be ported. from doing some semi in-depth research on head porting. i have found that a slight clean up, and port match is the best idea for my current setup and needs. the head will include, most likely hks 264/272 cams 1 mm oversized valves, and at some point a sheet metal intake manifold from polk. my ultimate question, is a slight clean up and port match and valve job enough for my setup. or is more head work needed or recommended that im overlooking. Any help would be appreciated. also who have you guys done business with, for head porting and who has good prices?
