Turbo lines/Intercooler lines question???
Cody Morris
97
Jun 5, 2002
i am adding turbo setup to car, and have none of the required water/oil lines and whatever other lines/pipes are needed. I know I need the IC pipes, but what other lines are needed to get the turbo properly operating. I will most likely give mitsubishigraveyard a call if someone can let me know exactly what things I need.
I have no clue. Check out Hanns race craft. they know alot about turboing N/A motors. Good luck.
You will need an oil feed line, an oil return line, a coolant feed line, and a coolant return line. You can make your own with banjo or npt fittings, but if you are looking for specific part numbers, I'd have no idea. Good luck.
Regards,
