- 66
- Nov 17, 2002
I dont know if people ever do this but here is what i did. I was getting crazy "phantom" knock all the time at part throttle at all rpms. so i tuned my car as best as i could using o2s and the knock sensor at WOT. since the knock sensor is grounded through its contact with the block i simply unscrewed the knock sensor, stripped the end of a length of wire and wrapped it around the threads on the knock sensor, then wrapped it with electrical tape to keep the wire in place, then i connected the other end of that wire to my negative battery terminal (any ground connection will do).
if you simply unscrew the knock sensor you get a engine check light since the knock sensor is not being grounded and you get a default knock of 9 ( if i remeber correctly) at any throttle position. so now with the knock sensor grounded, i get no knock ever, ive been running my car like this for a few months now and it is better than ever, so if i am getting any knock i dont know about it doesnt seem to be a problem. i just tune with O2s and EGT...i need to get on a dyno with a wide band.
anyway just thought some of you would like to know this since a lot of people have "phantom" knock.
(btw, the word is foolhardy, not fool-heartedly, see
