Water Pump
dbritt
178
Jun 9, 2003
Clemson, South Carolina
In 1g AWDs: After all bolts are removed from the water pump (that are holding it to the block) and everything is out of the way...do I just need to pull really hard to get it to come off? Or is there another bolt/clamp/something on the line attached to the pump that I need to detach first?
Thanks
The part touching the gasket was already loose, it was the part connecting to the pipe that was being a pain. I used a crowbar to pry it off and it finally did. Thanks
