Fuel filter
20gst
174
Jan 5, 2003
I got my new fuel rail, its from Injector Clinic. Also got my Aeromotive A1000-6 fp/regulator and hose fittings etc. Im doing the whole fuel upgrade with -6AN from the fuel tank and the return as well.
Ok I also ordered a Russell fuel filter from Jegs 130gph 70-75psi rated 40 micron disc-type element, bi-directional.
The question is will this filter be ok ? People are telling me not to use it that I need a 10 micron filter...Im just wondering if I need to order a different filter before I do my fuel upgrade this weekend comming up, or if I will be fine with the Russell I already got ? Thanks..:confused:
I hope that filter works better than the Earl's inline one. I tried it and did not have any luck with it-- maybe it was my stock pump with no rewire not being able to push enough fuel through it, but my EGTs skyrocketed until I put the stock filter back on (kept the -6AN line from the filter to the rail, though, thanks to an adapter that screws straight into the stock filter).
i have the same russell filter you're talking about, i believe. i'm having problems with it leaking though, to the point where the fuel will squirt out. i pulled it apart and the oring is fine, so i put it back together and tightened it up. it doesn't squirt now, but still leaks like crazy. i'm going to try a new oring, and if that doesn't work, i'm just going to get the aeromotive that i wanted in the first place.
Just to update, I did examine the innards of the Earl's filter I have, and it looks fine. I can also blow through it either way with no apparent "backpressure". I don't know why it wouldn't work for me....
