jdmawd
Banned Member
- 3,318
- Mar 20, 2002
GreenBelt,
I have a greddy turbo timer (with harness) everything appears to be wired up correctly. Here is the problem, all of the timer functions work properly in regard to reading rpm and voltage. Now for the fun stuff. when the key is removed everything electrical is kept on for the count down. Which the timer does properly. The only thing that does not stay running for the count down is the motor. dash lights,radio,fans all stay powered until the timer finishes the count down, except for the motor.
Anyone have similar problems with the greddy or any other brand turbo timer? if so how did you correct it if you were able to. Also the timer is ground to its own ground source and is not piggybacking any other ground. The parking brake wire is also connected correctly.
so I just chose to keep it for the time being.
