What do you guys think of this setup?
truwarrior
1,422
6
Dec 19, 2002
Current mods are:
Basic tuneup
rsr downpipe
rsr catback
apexi intake
egt
boost gauge
Next after the 60K belt change and a pump upgrade, and maybe a uip and bov change or else maybe just the BOV, I'm thinking about getting a small t28, with a acvr or what ever that apexi boost controller is and then lastly a small greddy fmic.
Right now I'm running 14 psi on the t25 with very little spin and hop. I actually think my downpipe is acting as a motor mount... Anyways how much max psi do you think I could run on a t28 in 1st and 2nd and not get spin? I'm guessing 12 psi in 1st and 14 psi in second then 15 psi 3rd and up.
I'm surprised that you're getting 14psi on the stock bov, especially without a boost controller. I'd deffinately upgrade at least your upper intercooler pipe and blow-off valve first. Then get your boost controller. I wouldn't run past 15 psi with your stock fuel system. Once you get your turbo and FMIC I'd stick to about 14 psi on the stock fuel system. Once you get a pump you could run 1psi, but not much more without bigger injectors and an afc.
