WhatsADSM
- 60
- Jan 9, 2003
Okay, I have been battling this problem for sometime now...
Since my new motor build my car has been acting funny with knock sums. Basically I get P-Knock like noones business but it is especially true in the lower gears.
For example when I let out the clutch in first gear and give it gas away from a light, my logger shows generally 35-42 counts. Then I shift to second and once I let the clutch out a give it gas I get the same thing.
However lets say I go to first and let out the clutch as explained above and I read on the logger 40 counts. Then I take my foot off the gas and put it back on.. The knock count completely goes away and my timing comes back.
Also important to note that if I go WOT, but starting without engaging the clutch I wont get any, or at least very little knock, running through all of the gears including the higher ones.
So the whole thing just doesnt make sense, there is no real reason I should be knocking in 1st as opposed to WOT in 3rd?!
All pertinent info about my setup:
2k mile old Built 6-bolt at about 8.3-8.4:1
Big16g currently at 16 psi.
New knock sensor (put in with the new motor)
3g lifters (no lifter tick here)
Walbro255, ChargedAir AFPR at 43 base, 550s, SAFC
2g MAS
My ideas:
-Knock sensor torque.. I couldnt find the spec anywhere in the manual.. What is the torque spec on this thing supposed to be. I have tryed snug and finger tight so far... maybe I should be using MORE torque?!
-Did the eagle dealer mess up and give me a 2g sensor? Are there any external differences between the 1g and 2g knock sensor?
Thanks in advance for the responses guys.
2g MAS
My ideas:
... my knock sensor (stock), is all goowie. som i ordered a new one hoping that will fix it.
