Test pipe and OBD2 2nd o2 sensor question...
RetardedAWD
146
Jul 15, 2002
For those of you that run test pipes how do you get around the 2nd o2 sensor problem? with check engine codes etc...?
Thanks for any info.
Well O2 works off of resistance so I suppose that I could use an in-line resistor to help combat a cel... Anyone know what resistance would be sufficient?
Thanks.
I have the service manual on my pc at work let me look for the CEL.
The P01070 is the ECU code associated with the CEL.
Later,
If you have a logger it will show the Check-Engine Code like on mine it said P0505 then beneath it says what it means. For the P0505 it says Idle Control System which means time to replace that ISC.
Later,
I just got the CEL checked today and i'm getting a p0505. This means my idle control system must be replaced??
