eclipsh
- 1,608
- 65
- Jun 16, 2005
Durango,
Colorado
I have been testing an alternative plumbing option for catch cans that I think could work very well. I am making extra use of the PCV valve port by routing an additional line off of it to the intake pipe with diaphragm style check valves on each line.
I replaced the PCV valve with a 1/8" pipe fitting I drilled out to maximize the ID. I then routed this to a cheap, temporary catch can I made from a spare power steering reservoir. From that can I have two lines exiting, one to the PCV port on the intake manifold and one to the intake pipe. Both exit lines have a check valve set up so they can only flow out of the can, not back into it.
When the manifold is at higher vacuum than the intake it shuts check valve 2 and only pulls fumes into the manifold. When the manifold is under pressure it shuts check valve 1 and only pulls fumes through the intake pipe.
I'm really not sure what happens when both tubes are pulling strong vacuum but it hardly matters so long as one of them is evacuating the valve cover, which they most certainly are. I verified this by checking the hose going to the valve cover during idle.
This setup can be further enhanced by using a catch can on the other breather line and upgrading the port to a 1/4" pipe piece.
