JDM engine?
dsmtalon91
Aug 13, 2002
Blaine, Minnesota
Does anyone know if a JDM 4G63 turbo engine will fit up perfect in my car. I have a 93 eagle talon tsi the fwd one. The JDM engine is about the same but it just has a bigger turbo and better internals then the north american engine. I have found some people who get these engines straight from Japan and I want to make sure that everything will hook up perfect. Would there be anything I would have to change.
Any input would be greatly appreciated.
Thanks
Just an FYI, the "JSPEC" engine is the same as the USDM. The only difference is the intake manifold. There are VERY few that come with the 16G turbo. You will be lucky if you happen to get one with the larger turbo. Other than that they bolt in just fine. I have one in mine.
JDM engine: 80% of them is the same as USDM expt. for some Cyclone manifold, 20% come with a 16G turbo, 5% RS model with big 16G turbo and yellow top 550cc injectors. I heard some come with a higher 8:5:1 compression or 8:8:1 with the 16G and RS model.
The install is not really direct, but close. Stuff like thermostat, oil cooler(optional), water pipe(optional), CAS, cyclone manifold(optional), power transistor, coil pack(optional) .. had to be replaced
Where would be the best place to find a JSPEC engine? I was looking at Nippon-Motors... are they pretty reputable?
NIC International is where I got mine from! Go to RRE website for the listings and all info.
I got the Big 16g and 510cc injectors with mine as well! I couldn't be happier with my engine thus far. It was very clean, and I got a hell of a deal on it. I paid about $1100 for my engine shipped!
