BCS question need help real quick
Turbonium
175
Jul 22, 2002
Ithaca, New York
Alright guys i need some quick help cause this bcs thing is messing with my head, i'm not geeting much for power and you can harly feel it when you hit boost you just slowly notice it in the higher rpm's. i'm not sure is my bcs is messing up if i just disconnect it will i mess aqnything up?? thanks
unless you put a mbc in there disconnecting the bcs will throw a check engine light, if it doesn't feel like its building boost, id pull the exhaust manifold throught the downpipe and check everything especially the turbo very carefully for cracks, also have you done the intake leak tester?? it sounds like a boost leak to me, its all on www.vfaq.com id go there and see whats up
later
jason
