- 44
- Jun 24, 2002
Has anybody installed a blitz FATT DC turbo timer?
I just intsalled mine today and I am having trouble with it. I bought the harness with it. I plugged the harness into the starter coupler as the directions said. I connected all the plugs to the correct plugs. Their is a white female connecter that is just hanging and I have no idea what its for. The directions don't have any instructions for this white connecter. So I didn't contected it to anything.
Anyway, I plugged the display remote to the control module and grounded all the grounds. I checked them with a test light to see if it was a good ground and it is. Their is a purple wire that is to be either conntected to a ground wire from the parking brake wire or just grounded, but it's has to have a ground signal at all times. So, I ground the wire to a bolt that didn't have any paint on it or anything. I check the ground and it was good.
With everything connected and ready to go I tested the Turbo Timer. The turbo timer turned on fine and I set it to the manual setting. I started the car and let it idle for a while then shut off the car and pulled out the key. The damn turbo timer turned off. I even took my car for a ride to see if that was it. And the turbo timer shut off when I pulled out the key.
The directions said if the purple wire isn't grounded correctly the turbo timer will shut off when the key is taken out. So, I tried grounding to a different place and the same thing happend.
The only thing I didn't try is gounding it to the brake ground. I'm not sure where it is? Is it that green wire that is connected to the hand brake? I was too pissed off and quit for today. Any HELP would be greatly apprecitated!
Thanks guys,
DanE
Sorry for the long explanation.
Thanks guys,
DanE
Thanks for the help. If anybody has any other ideas it would be helpfull.
You guys are cool
Thanks for all the help.
