Help ASAP (spark plug wires)
Eclipseturb1384
105
Dec 17, 2002
Torrington, Connecticut
got new wires and now i cant remember which one plugs in to where?!?!
stupid %*#@ i am, but can somebody tell me the order they go??
from VFAQ:
Spark plug wire routing - if you removed your spark plug wires without paying attention to the routing, don't worry. On 4G63s, the spark plugs are numbered from the timing belt/driver's side - #1 is closest to the timing belt. The connections to the coilpack are 4123, with 4 being closest to the head. See this pic. Note that since 4G63s use a waste spark system that fires 1/4 and 2/3 together, you can also hook the wires to the coilpack as 1423 and 1432 and it will work fine. Note that wire #3 is longer than #4 - shortest to longest, they are 1243. Tom Stangl
take care!
Ok, so what will happen if you put them in the wrong plug well. This couldn't be why I get misfires could it? Im gonna check tomorrow.
