Intake pipe questions.
9DTSiAWD
331
Jan 1, 2003
I have searched and didnt come up with an answer.
There are just tons of intake pipes out there and i know this question has been answered but i couldnt find it. Ok i have a 1990 TSi AWD i want to run the fastest 1/4 i can but with a small or big 16g (have not decided yet) What Dejon Tool intake should i buy, like what size or modle. I will be running it on the factory 14b for at least 3or4 months, then i will be upgradeing to a 16g. Thank you in advanced.
You should buy my 3 inch dejon tool intake pipe that I have for sale. :D
Kind of depends on your future plans.....FMIC or no?
I'd go with the 3 1/2" 1gMAS Curved Intake Pipe w/ a K&N
and they will ask you for some specifications on it, such as bov tube, how long it is, etc.
The larger Dejon pipes will NOT FIT on a 14b or 16g due to the placement of the wastegate actuator.
If you read Dejon's catalogue carefully, you will see this explained.
Assuming you want to keep the stock aircan in the stock location for now, there's really only one intake that meets all your criteria; you just need to decide which port(s) you want on it.
Make sure you tell them which turbo you are using it with, and ask for the spacing ring for the turbo end of the intake. Mine came without, and I had to cut up some 2.25" hose I had lying around to make the spacer. Fitting it was a ^%$^&%$.
Originally posted by 9DTSiAWD
ok so would a 3in dejon tool intake fit or would it not fit the stock 14b turbo?
I have a 14B on my 2g WITH a 3" dejon intake. It's VERY TIGHT but it fits.
Does anybody know from experience what would be better, a dejon tool intake w/ k&n or and injen w/ k&n??
