Marcus
- Jan 20, 2003
I have a big16g, 550's, afc, denso pump, 2gmas, 2.5 back, and pocketlogger. I want to know how much boost i can run on 93 octane and still be safe to the motor, i could care less if the turbo craps out.
Originally posted by FINETUNED
I have the same setup less the injectors and anything over 15psi is fuel-cut why?????
Originally posted by nine5raptor
plugs and wires won't fix a fc problem...
he is hitting the calculated max airflow that the stock injectors can handle and still be within the preset bounds burned into the ecu. injectors are the answer.
a fcd is dangerous. the fuel cut is a warning that you are running out of injector.
fuel cut is independent of "NOT ENOUGH FUEL...." the amount of air you flow at XXpsi will depend on the VE of the engine and i/e restrictions. If we had the same setup except for you had a 16G and I had a 14B, we would flow nearly identical amounts of air.
Originally posted by PimpBlackTalon
huh? what a waste of money buying bigger turbos! if they don't do any good i wonder why they make the cars faster? hmmmmmm![]()
btw.. what is VE?
:laugh:Originally posted by PimpBlackTalon
btw.. what is VE?
SARCASM -------^
