TSI15PSI
- 30
- Jun 9, 2002
Utah
I have a 91 TSI....my buddy and I were just looking at the engine and I looked at his jaw and it dropped. The reason being was that he said I was missing my oil/coolant line that runs from the head behind the turbo and goes to the oil cooler?? I went and asked a buddy if he happened to have a spair? He did. I was just wondering what are the adverse effects of this not being on...and what you guys think that I should do. Thank you very much.
TSI
TSI
. Anyway, I have a red valve cover wich signifies to me that it is a VR4 block. I do not have oil everywhere!! Thank god. The previous owner warped the head and the replaced the head...belt..etc. I have had some issues with it getting on the warm side. I am trying to figure out if the line not being their is causing this problem. I am positive that I have an oil cooler!! just not the 90 cooler(my bud has a 90 and I have seen it), however I do have the mount on the bottom drivers side for this conversion. When I look on the passenger side below the water neck there is a nut with a clamp restricting flow, I am imagining that is where the oil comes from. Now when you look on the drivers side to the left of the cooler there is a line that looks to have been cut....nothing comes from this line. What in the H!@#.....please let me know if this sounds right to you and how to alleviate the problem. Thanks alot!!!!
