Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Bolt-on Tech
Bolt-on Tech 4G63 intake, exhaust, intake manifold, ignition, fuel system, cooling, etc.
Reply
LinkBack Thread Tools
Old 01-21-2003, 12:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
Tech Posts: 340
Photos: 3
Classifieds Rating: 0
Reputation: airbrat is an unknown
Question Diagnos my Shifting Problem
whenever I shift inbetween gears my RPMS actually raise momentarily when I depress the clutch. Kinda like when you're riding the clutch or a newbie w/ a 5spd.
any reason why my RPMs rise like that when shifting?
View photos of this member's car
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 01-21-2003, 12:50 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
Tech Posts: 76
Photos: 1
Reputation: SD GST is an unknown
sounds like a slipping clutch.. Time for a new one..
Visit SD GST's homepage!  View photos of this member's car
Old 01-21-2003, 12:54 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
Tech Posts: 318
Photos: 6
Reputation: 9DTSiAWD is an unknown
Quote:
thats what it is.
Visit 9DTSiAWD's homepage!  View photos of this member's car
Old 01-21-2003, 01:01 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
Tech Posts: 340
Photos: 3
fawkery!
Old 01-21-2003, 01:04 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 71
Reputation: Ghettoraid is an unknown
Q:: my clutch plate has the flywheel riveted to it.
Is it more cost effective and beneficial (in the long run) to buy a nice clutch AND like..a fidanza alu flywheel?
Old 01-22-2003, 07:04 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
Tech Posts: 340
Photos: 3
is there anything else that would cause this???
Old 01-22-2003, 07:37 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Tech Posts: 55
Photos: 7
Reputation: Eclipsor16G is an unknown
I disagree. I don't think it's a slipping clutch. I may also be misinterpreting your description of the problem.
The rise in RPMs that you describe: this happens when the clutch is pressed into the floor, correct? If it were to happen after you let off the clutch (while it's engaging) then I would lean towards a slipping clutch. What you're describing, however, sounds almost like a stuck accelerator cable that's causing the engine to rev freely when the clutch is pushed in.
If you're driving hard and shift quickly, does your clutch grab well and do the RPMs drop right into the next gear and off you go? Or does it engage slowly and the RPMs kinda stay up for a sec then slowly go down?
Lastly, how does your car idle?
Chris
Visit Eclipsor16G's homepage!  View photos of this member's car
Old 01-22-2003, 07:50 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
Tech Posts: 340
Photos: 3
you're right. the rise in RPMs happens as I push in the clutch, not disengaging it. Its odd because it is never consistant. Maybe once or twice a week this might happen.
My idle is great. Once the idle was bouncing from 800 to 1500 rpms! I had no idea what the hell was causing it so I disconnected my battery and let the ECU reset. Ever since I had no problems.
Old 01-22-2003, 09:05 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
Tech Posts: 1,777
Reputation: nine5raptor is an experienced, knowledgeable member worth listening tonine5raptor is an experienced, knowledgeable member worth listening tonine5raptor is an experienced, knowledgeable member worth listening tonine5raptor is an experienced, knowledgeable member worth listening tonine5raptor is an experienced, knowledgeable member worth listening tonine5raptor is an experienced, knowledgeable member worth listening to
I doubt it does. bolted to most likely. the friction surface is probably riveted to the disk hub, but every car I've seen has the flywheel bolted to the pressure plate.
If you mean your pressure plate is riveted to the flywheel, then it is pointless to have a clutch at all as the engine cannot disengage from the transmission
Old 01-22-2003, 09:06 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Tech Posts: 1,777
Quote:
??? which is it? pushing in the clutch IS disengaging it.
Old 01-22-2003, 09:21 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
Tech Posts: 55
Photos: 7
I'm sure you could have figured out what he meant, even though he used some terms incorrectly. He clearly stated that it happens when the clutch is pushed in (disengaged).
Chris
Old 01-22-2003, 09:25 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
Tech Posts: 55
Photos: 7
I would recommend using the stock flywheel, but that's just me. I'm sure the Fidanza units, and other aluminum flywheels, will work fine though. Lots of people complain about low speed driveability with light flywheels, but it's nothing to be too worried about.
And just so you get a clear understanding of how things work, and what terms to use... the flywheel is bolted to the crankshaft. The clutch disc is in between the flywheel and the pressure plate (which is bolted to the flywheel).
Chris
Old 01-22-2003, 11:15 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
Tech Posts: 340
Photos: 3
sorry, got my words all mixed up. the rise in RPMs is only when I push in my clutch "disengaged"
Reply
Bookmarks
Thread Tools
» Recent Build Entries
Night 7 - Almost There
by: knochgoon24
Night 6 - The end is near.
by: knochgoon24
Night 5
by: knochgoon24
Night 4
by: knochgoon24
Warm weather= more work done
by: badabing33a
» Recent Tech Threads
Title, Username, & Date
Best turbo for a DD Automatic?
by: VeryFast2gDSM
AFX ECU questions
by: nothingfiction
Ecm Link V3 CD
by: stroked_AWD
Arp headstuds
by: gst fat
What to purchase first?
by: konvict1981
» Latest Gallery Photo
User sek_phok
» Current Poll
What kind of build are you working on?
Street/Strip - 79.52%
365 Votes
Full Drag Race - 3.49%
16 Votes
Track Day/Time Trials - 4.36%
20 Votes
Full Road Race - 5.01%
23 Votes
Autocross - 6.97%
32 Votes
Dyno Queen - 0.65%
3 Votes
Total Votes: 459
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.2
