First Good Mod?
He means have everything checked out.
Transfer case, clutch, timing belt, water pump, any leaks, anything that could posibly go wrong with your car you want to take care of before you start to modify.
Other than that, get the intake
Yeah after you make sure everything is good on it belts, plugs, wires. When i bought mine he said he had a recent maintinence done on it. I still went ahead and changed everything just so i know for sure i have new stuff on it. But for a good first Mod, i would go like this. IMO: I would go with a Boost Gauge and then a K&N then other stuff. Look here for more stuff. http://www.dsmtuners.com/tuning-guide/ Just pick your year under performance and follow by it. Its about the best outline you could probably get. Other than OUR opinions.
I would say you should get the boost guage, BOV (if your a 2g), and K&N FIPK first in that order and then a MBC next
