talontsi01
- 640
- 1
- Oct 6, 2002
Detroit,
Michigan
I got a quick question. Its about my turbo. I'm running 15 psi right now. When i start my car, my boost gauge shows -15 (15 vacuum). It's when I push in the clutch, the boost goes down to -20. When i let off the clutch and floor the gas, the boost gauge reads up to about 10 psi at most. When i push in the clutch to shift into second, the boost reads back down to -20, where it should be -15. It does this when i shift for all of the gauges. For each gear, starting with first, the boost increases better and better. First gear is the worst. Second is a little better. Third is fine...and it keeps getting better. But first gear is so bad that I almost dont even get boost most of the time unless i floor the gas pedal 100%. I hope someone can tell me whats wrong.
thanks
thanks
and give you probably .0003 more psi there.
