I'm working on the list for 2Gs slowly guys so please bare with me...
Suspension:
Front(AWD):
1990-1994:
-Axle Shaft Nut: 144-188 ft. lbs.
-Ball Joint Stud Nut: 43-52 ft. lbs.**
-Brake Caliper Bolt: 58-72 ft. lbs.
-Clamp-to-Cross-Member Nut/Bolt:
Bolts (short): 58-72 ft. lbs.**
Bolts (long #7 on bolt head): 58-72 ft. lbs.**
Bolts (long #10 on bolt head): 72-87 ft. lbs.**
Nut: 25-34 ft. lbs.**
-Control Arm-to-Cross-Member bolt: 72-87 ft. lbs.**
-Cross-Member Brace Bolt: 51-58 ft. lbs.
-Cross-Member #2 Rear Bolt: 58-72 ft. lbs.
-Cross-Member Bolt (left):
Front: 58-72 ft. lbs.
Rear: 51-58 ft. lbs.
-Stabilizer Bar Link Nut: 25-33 ft. lbs.
-Stabilizer Bar Mounting Bracket Bolt: 22-30 ft. lbs.
-Strut Shaft (Self-locking nut): 43-51 ft. lbs.
-Strut-To-Body Nut: 29-39 ft. lbs.
-Strut-To-Knuckle Bolt: 80-101 ft. lbs.
-Tie Rod Nut: 17-25 ft. lbs.
** Tighten to specs. with vehicle at normal operating height.
1995-:
-Axle Nut: 145-188 ft. lbs.
-Caliper Assembly Mounting Bolt: 65 ft. lbs.
-Center Member To Body: 58-65 ft. lbs.
-Compression Lower Arm To Cross-Member: 60 ft. lbs.
-Compression Lower Arm To Knuckle: 43-52 ft. lbs.
-Drive Shaft Nut: 145-188 ft. lbs.
-Dust Shield To Knuckle: 6.5 ft. lbs.
-Hub Assembly To Knuckle: 65 ft. lbs.
-Hub Nut: 145-188 ft. lbs.
-Joint Assembly & Gear Box Bolt:13 ft. lbs.
-Knuckle To Compression Lower Arm: 43-52 ft. lbs.
-Knuckle Upper Mounting: 21 ft. lbs.
-Lateral Lower Arm To Cross-Member: 71-85 ft. lbs.
-Lateral Lower Arm To Damper Fork: 65 ft. lbs.
-Lateral Lower Arm To Knuckle: 43-52 ft. lbs.
-Power Steering Brackets To Cross-Member: 51 ft. lbs.
-Power Steering Oil Pump To Bracket: 21-29 ft. lbs.
-Power Steering Pipe Connections: 11 ft. lbs.
-Power Steering Pressure Hose To Pump (Non-Turbo): 42 ft. lbs.
-Power Steering Pressure Hose to Pump (Turbo): 13 ft. lbs.
-Stabilizer Bar Bracket: 28 ft. lbs.
-Stabilizer Link To Stabilizer Bar: 28 ft. lbs.
-Stabilizer Link To Dampener Fork: 28 ft. lbs.
-Stay To Cross Member: 51-58 ft. lbs.
-Strut Top End Nut: 16 ft. lbs.
-Strut Lower Mounting: 75 ft. lbs.
-Strut Upper Mounting Nut: 32 ft. lbs.
-Tie Rod End To Knuckle: 21 ft. lbs.
-Upper Arm To Knuckle: 21 ft. lbs.
-Wheel Lug Nuts: 88-108 ft. lbs.
Rear(AWD):
1990-1994:
-Axle Shaft Companion Flange Nut-To- Rear: 116-159 ft. lbs.
-Ball Joint Nut: 43-52 ft. lbs.
-Brake Tube Bracket-To-Rear Shock Absorber: 12-19 ft. lbs.
-Companion Flange-To-Drive Shaft: 40-47 ft. lbs.
-Lower Arm Ball Joint To Knuckle: 43-52 ft.lbs.
-Hub Assy. To Knuckle: 144-188 ft. lbs.
-Joint Assy.: 11-16 ft. lbs.
-Lower Arm Clamp To Cross-Member (Bolt): 58-72 ft. lbs.
-Lower Arm Clamp To Cross-Member (Nut): 25-34 ft. lbs.
-Caliper Mounting Assy. Bolt: 58-72 ft. lbs.
-Center Bearing Bracket: 26-33 ft. lbs.
-Center Member To Body: 58-72 ft. lbs.
-Drive Shaft Nut: 144-189 ft. lbs.
-End Plug: 36-51 ft. lbs.
-Feed Tubes: 9-13 ft. lbs.
-Gearbox To Bracket To Cross-Member: 43-58 ft. lbs.
-Knuckle To Strut Assy. 80-101 ft. lbs.
-Lower Arm To Knuckle: 43-52 ft.lbs.
-Lower Arm To Cross-Member: 65-80 ft.lbs.
-Upper Arm To Cross-Member: 101-116 ft.lbs.
-Upper Arm To Knuckle: 43-52 ft.lbs.
-Cross-Member Bracket To Body: 51-61 ft.lbs.
-Cross-Member Bracket To Cross-Member: 80-94 ft.lbs.
-Shock Absorber Upper Mounting Nut: 29-36 ft.lbs.
-Shock Absorber Lower Mounting Nut: 58-72 ft.lbs.
-Strut Top-End Nut: 43-51 ft. lbs.
-Strut Upper Mounting Nut: 29-39 ft. lbs.
-Stabilizer Link To Stabilizer Bar: 25-33 ft.lbs.
-Stabilizer Bar Bracket: 22-30 ft. lbs.
-Stabilizer Link: 25-33 ft. lbs.
-Wheel Bearing Nut: 144-188 ft.lbs.
-Tie Rod End Ball Joint: 17-25 ft. lbs.
-Tie Rod End To Rack: 58-72 ft. lbs.
1995-:
Axle Nut: 145-148 ft. lbs.
Brake Caliper Assembly: 36-43 ft. lbs.
Differential Mounting Bracket To Cross Member: 72 ft. lbs.
Differential Mounting Bracket To Differential: 65 ft. lbs.
Differential Mount Support Bolts: 33 ft. lbs.
Lower Arm To Cross Member: 71 ft. lbs.
Lower Arm To Knuckle: 71-72 ft. lbs.
Lower Shock Absorber Mounting Bolt: 71-72 ft. lbs.
Piston Rod Tightening Nut: 16 ft. lbs.
Propeller Shaft To Differential: 22-25 ft. lbs.
Rear Hub To Knuckle: 54-65 ft. lbs.
Stabilizer Bar Mounting Bracket: 7-10 ft. lbs.
Stabilizer Link To Lower Arm: 28 ft. lbs.
Toe Control Arm To Cross Member: 50-56 ft. lbs.
Toe Control Arm To Knuckle: 20-21 ft. lbs.
Trailing Arm To Body: 99-114 ft. lbs.
Trailing Arm To Knuckle: 85-101 ft. lbs.
Upper Arm To Knuckle: 71 ft. lbs.
Upper Arm Bracket To Body: 28 ft. lbs.
Upper Arm Bracket To Upper Arm: 41 ft. lbs.
Upper Shock Absorber Mounting Nut: 32 ft. lbs.
Drive Shaft/U-joints:
1990-1994:
-Center Support Bearing Mount Nut: 22-29 ft. lbs.
-CV Joint Nut: 22-29 ft. lbs.
-Drive Shaft Companion Flange Nut: 116-159 ft. lbs.
-Drive Shaft-To-Differential Flange Nut: 22-25 ft. lbs.
-Drive Shaft Yoke Nut: 116-159 ft. lbs.
1995-:
Transfer Case:
1990-1994:
-Drain/Fill Plug: 22-26 ft. lbs.
-Driven Bevel Gear (Lock Nut): 103-118 ft. lbs.
-Extension Housing Bolt: 11-16 ft. lbs.
-Front Exhaust Pipe Mounting Bracket Bolt: 15-22 ft. lbs.
-Front Exhaust Pipe (Self-Locking Nut): 22-30 ft. lbs.
-Transfer Case Adapter Bolt: 26-31 ft. lbs.
-Transfer Side Cover Bolt: 26-31 ft. lbs.
-Transfer Case Assy. Mounting Bolt: 40-43 ft. lbs.
-Case Cover Bolt: 71-89
in. lbs.
1995-:
Auto Trans/Transaxle:
1990-1994:
-Sprang Rod Support: 15-19 ft. lbs.
-Tie Rod End To Knuckle: 17-25 ft. lbs.
-Transaxle Control Cable Adjusting Nut: 7-10 ft. lbs.
-Transaxle Control Cable To Body: 7-10 ft. lbs.
-Transaxle Mount Bracket To Transaxle: 43-58 ft. lbs.
-Transfer Lock-Nut: 145-166 ft. lbs.
-Pressure Check Plug: 6-7 ft. lbs.
-Pulse Generator: 7-9 ft. lbs.
-Pump Housing To Reaction Shaft Support: 7-9 ft. lbs.
-Selector Lever Assembly: 7-10 ft. lbs.
-Shift Lock Cable To Selector Lever Assembly: 3-4 ft. lbs.
-Speedometer Sleeve Locking Plate: 2-4 ft. lbs.
-End Clutch Cover: 5-6 ft. lbs.
-Hose Bracket: 2-4 ft. lbs.
-Inhibitor Switch: 7-9 ft. lbs.
-Lever Assembly To Bracket Assembly: 10-14 ft. lbs.
-Lock Plate: 26-32 ft. lbs.
-Manual Control Lever Nut: 13-15 ft. lbs.
-Manual Control Shaft Setscrew: 6-7 ft. lbs.
-One-Way Clutch Outer Race: 18-25 ft. lbs.
-Ball Joint To Knuckle: 43-52 ft. lbs.
-Bearing Retainer: 12-15 ft. lbs.
-Bell Housing Cover To Engine: 7-9 ft. lbs.
-Clamp To Body: 3-4 ft. lbs.
-Converter Housing: 14-16 ft. lbs.
-Drain Plug: 22-25 ft. lbs.
-Drive Plate To Converter: 34-38 ft. lbs.
1995-:
-Air Intake Hose Connections: 3 ft. lbs.
-Bell Housing Cover: 7-9 ft. lbs.
-Compression Arm Connection: 44-52 ft. lbs.
-Cross-Member To Body: 51-58 ft. lbs.
-Cross-Member To RH Stay: 51-58 ft. lbs.
-Cross-Member To Transaxle: 42 ft. lbs.
-Damper Fork to Lateral Lower Arm: 65 ft. lbs.
-Drive Plate Connecting Bolt: 33-38 ft. lbs.
-Lateral Lower Arm Connection: 44-52 ft. lbs.
-Mounting Bracket To Body: 51 ft. lbs.
-Mounting Bracket To Transaxle: 42 ft. lbs.
-Oil Level Gauge Bracket: 17 ft. lbs.
-Rear Roll Stopper Bracket: 51 ft. lbs.
-Stabilizer Link To Damper Fork: 29 ft. lbs.
-Starter Motor to Transaxle: 22 ft. lbs.
-Tie Rod End Nut: 18-25 ft. lbs.
-Torque Converter Connecting Bolt: 33-38 ft. lbs.
-Transaxle Control Cable Connection: 7 ft. lbs.
-Transaxle Lower Coupling Bolts: 35 ft. lbs.
-Transaxle Upper Coupling Bolts: 22-25 ft. lbs.
Brakes:
1990-1994:
-Backing Plate Bolts: 36-43 ft. lbs.
-Bleed Screws: 8-11 ft. lbs.
-Brake Booster To Dash: 18-25 ft. lbs.
-Brake Hose To Rear Caliper Banjo Bolt: 5-7 ft. lbs.
-Caliper
