Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Bolt-on Tech
Bolt-on Tech Intake, exhaust, intake manifold, ignition, fuel system, cooling, etc - specific to 4G63 turbocharged DSMs.
Reply
LinkBack Thread Tools
Old 11-19-2005, 01:54 PM   #31 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Fb90gsT is an unknown
Thanks, I knew it was around there.
Offline
Related Auctions
Sponsored Links
Old 11-19-2005, 01:57 PM   #32 (permalink)
Proven Member
wolf20043's Avatar
Region: Rocky Mountain
Classifieds Rating: (10)
Reputation: wolf20043 is extremely helpful and trustworthywolf20043 is extremely helpful and trustworthywolf20043 is extremely helpful and trustworthy
Quote:
Originally Posted by defrag010
I hope to god you're not torquing your pressure plate bolts down that tight. Jeez, they're only M10's.
I always torque them down to 18 ftl/bs
chit bro, sorry I saw flywheel and not the pressure plate . My bad . but now you have the flywheel specs too.
Mike
Offline
[posts] Reply With Quote
Old 11-19-2005, 02:00 PM   #33 (permalink)
Proven Member
no problem.
Offline
Old 11-19-2005, 02:11 PM   #34 (permalink)
Proven Member
Region: Southeast
Reputation: FourG63 97GST is more helpful than not
Pressure plate 14ft lbs
Flywheel 98ft lbs
if you want to get specific. And use locktite please, the red one, not the blue
____________________________
Agim
Offline
Old 01-20-2006, 07:15 PM   #35 (permalink)
Proven Member
Reputation: pnklmnd is more helpful than not
Torque Specifications specs [Merged 2-8]
Im doing a head gasket, and was wondering what to torque the bolts to.
Offline
Old 01-20-2006, 07:28 PM   #36 (permalink)
Proven Member
wolf20043's Avatar
Quote:
on a cold engine you would tourqe 65 to 72 in the right sequence. #1 being the middle stud on the exhaust side, #2 being the middle intake,#3 to the left on the exhaust side,#4 caddy corner from #3, #5 to the left of the middle intake, #6 caddy corner from that, #7 last on the left intake, #8 last on the right exhaust, #9 last on the left side exhaust, and #10 last on the intake right side.
Mike
(right and left as you look from the front)
Offline
Old 01-20-2006, 10:17 PM   #37 (permalink)
Proven Member
Region: Gulf Coast
Classifieds Rating: (8)
Reputation: gsxtacy is extremely helpful and trustworthygsxtacy is extremely helpful and trustworthygsxtacy is extremely helpful and trustworthy
How do you get as far as doing a head gasket with ZERO refrence material? (Haynes/Chiltons/DSM Manuals/CDs)
Here is something I just dug up real quick, hope it helps....some.
gsxtacy
Gsxtacy
Offline
Old 01-20-2006, 10:46 PM   #38 (permalink)
Proven Member
Thanks.
To be honest i have never looked at a haynes, chiltons, DSM cd or the like. Ive done 5+ motor swaps, bunch of clutches. The only reason i ask is id like to know the exact torque they need to be.
Offline
Old 01-20-2006, 11:03 PM   #39 (permalink)
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
Please note that if you are using ARP headstuds that you will need to torque to 80 ft/lb and using the ARP moly lube
also, if you are using a 1g headbolt, that the torque sequence (not the order in which you torque, but how you torque) is DIFFERENT because the 6 bolt studs are not a stretch-type like the 7 bolt is. use the above sequence ONLY for a 7 bolt..
~Tom
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 01-21-2006, 12:50 AM   #40 (permalink)
Banned
Amazin' Wasian's Avatar
Classifieds Rating: (-9)
Reputation: Amazin' Wasian is more helpful than not
here you go....heres a link to a complete engine overhaul it has every torque spec you could ever need..... http://www.ecanfix.com/~manualcd/index2.htm
Offline
Old 01-21-2006, 10:41 AM   #41 (permalink)
Proven Member
wolf20043's Avatar
Exactly. The 1g only needs to be tourqed once.
Mike
But the the pic of the tourqe sequence in the is correct.
Offline
Old 01-21-2006, 07:56 PM   #42 (permalink)
Proven Member
Scrymerr's Avatar
Region: NorCal
Classifieds Rating: (3)
Reputation: Scrymerr is pretty helpful and trustworthy
So I assume the above poster is correct in saying when using ARP's the torque spec is 80ft/lbs?
Offline
Old 01-21-2006, 08:26 PM   #43 (permalink)
DSM Wiseman
project_tsi's Avatar
Region: Midwest
Classifieds Rating: (12)
ARP states 75 ft/lbs. using their moly lube. However, I generally go a bit over that.
Dan Kasun
93 GSX
05 Ram 1500
06 GSX-R750
Offline
Old 01-22-2006, 11:30 AM   #44 (permalink)
DSM Wiseman
Region: Tri State
I got your PM, but I guess i'll post up here for the rest to see. if you are using STOCK 6 bolt headbolts, torque once, in the appropriate sequence to 75 lb/ft. oh, and don't reuse your headbolts if you're planning to. even though they are not stretch-type, it could be possible that they will not fasten as well once you remove them
ARP's are good to torque in the above sequence, but in 3 steps. 30, 60 , 80.. or whatever interval you'd like.
~Tom
Offline
Old 02-15-2006, 06:11 PM   #45 (permalink)
Proven Member
Region: Pacific Northwest
Reputation: Birt96gst is an unknown
6bolt Fidanza Flywheel torque?
What do I torque my fidanza flywheel down to on my 6bolt
Need to know asap last thing holding me up
thank you
Offline
Old 02-15-2006, 06:32 PM   #46 (permalink)
DSM Wiseman
Quasimondo's Avatar
Region: Tri State
98 ft lbs
-Armando-
Offline
Old 02-15-2006, 06:35 PM   #47 (permalink)
DSM Wiseman
Region: Midwest
96-100 ft. lbs. Torque in a star pattern, just like a wheel lug. I generally torque in steps of 3. 33-66-100, or close.
Dan Kasun
93 GSX
05 Ram 1500
06 GSX-R750
Offline
Old 02-15-2006, 06:50 PM   #48 (permalink)
Proven Member
thank you
Offline
Old 06-28-2006, 05:20 PM   #49 (permalink)
Proven Member
JBDdsmer610's Avatar
Region: Tri State
Classifieds Rating: (1)
Reputation: JBDdsmer610 is an unknown
1G-specific Flywheel torque spec and presure plate
I need to know the flywheel and presure plate torque specs for my 1g asap doing the clutch right know
Offline
Old 06-28-2006, 05:49 PM   #50 (permalink)
New Member
Region: Midwest
Reputation: 95FlamingTalon is an unknown
The flywheel should be torqued to 25 ft. lbs.(35Nm) and the pressure plate should be torqued to 16 ft. lbs. (22 Nm). These specs came from a Chilton manual and they are specifically for a 90-94 dsm.
Offline
Old 06-28-2006, 05:50 PM   #51 (permalink)
Proven Member
Region: Mid Atlantic
Reputation: erebusknight is more helpful than not
dont forget to tighten it in stages and tighten it like you torque a wheel
Offline
Old 06-28-2006, 07:49 PM   #52 (permalink)
Proven Member
Reputation: blackrosenova40 is more helpful than not
My Hayes manual says between 94-101 for the flywheel.......?
Offline
