CH152
- 296
- Oct 8, 2002
Lexington,
Kentucky
This is the full story so bare with me here:
I arrive back to where I had my car parked from being away at a wrestling tourney. Anyhow, I get in my car it starts just fine. I let it idle for about 20 sec or so before I attempt to back it out of the parking spot. My Dad was following me on the way home too. SO IF ANYTHING DID HAPPEN HE COULD KINDA GET AN IDEA. (Well something did) I drive no more than about 2 miles before I start to get on it to make sure that the 15w 50 Mobil 1 Synthetic motor oil with 20 % Lucas oil treatment is good and warm up to operating temperature. I was in 5th gear at the time doing 50 on the Speedo; Dad was following me close so I figured what the hell lets drop her down a gear or two.
I shift down to 4th and then into 3rd where I get on the gas to about no faster than 70 by the time I let off. The boost builds and then all of a sudden, my car sounds like I am running over gravel or as if I hit something on the bottom side of the car... I let off the gas downshifted to 2nd and it grinded all the way through it. I pull off the road get out as I walk around to the back while my dad pulled up beside behind me. I looked on the ground and I noticed a LONG oil or trans fluid line (havent checked which one it is) streaking the ground (FROM WHERE I HIT THE GAS). Dad said that when I got on it he could here my exhaust pick up and then he saw sparks shooting out from underneath of the car along with smoke. We popped the hood and couldnt see anything because it was so dark outside. I tried to crank it over and I pushed in the clutch and well it cranked over but it was so slow as if the battery was low but it did move. What do you all think that it is? The tranny, the rods, or the turbo may have exploded? I checked underneath the car and couldnt see oil leaking on the ground. If you all would please help me with what you all think that the problem is.
And if you would post some links regarding engine blocks and tranny's just incase that this is what is broken. My mods are in my info. With the bottom end being able to hold 400hp and with my mods I am far from it, which makes me think or lean more towards a turbo exploding or a tranny. The car is still parked on the side of the road 1 mile from my house we are flat bedding it tomorrow I guess then I will get to see the REAL problem. Any and ALL help would be appreciated. As for now I have to pull out old tanner the 1990 Honda Accord EX.
I will try to answer any questons that you guys have to the best that i can so i can figure this thing out!!!
Thanks Guys
Thanks Guys
. Anyhow I drained the motor oil. Uh Oh... I had some antifreeze in it???? I then pulled the downpipe off and it had coolant in it too. No motor oil in it though. Once that was done, I dropped the oil pan. DAMN, number one cylinder connecting rod was gone; the rod cap got bent into a C shape and the oil pick up was broken off. I was like ok maybe this isnt to bad here. I got back up top and pulled the timing cover off. Crap... The timing belt was loose. Went back down and the Number one rod pushed the balance shaft straight thru the block causing the timing belt to slip off and run into the block and get stuck. The balance shaft is in a huge HUGE curve outside of the block. NO SIGN of a connecting rod still.... It broke in 10,000 small pieces I am guessing they flew into the road.
