redeclipse7782
- 463
- 7
- Oct 20, 2004
Worcester,
Massachusetts
I recently had my engine rebuilt (6 bolt 2.3 stroker) I started the car up and drove it 3 miles when I pulled over the coolant was bubling over the reservoir. I changed the lower radiator hose, thermostat, and radiator cap. Car started up and the system pressurized coolant was not over flowing.
I then notice I have coolant leaking out the front freeze plug behind the intake manifold. All freeze plugs were changed out when the engine was re-built. I also noticed there was coolant leaking out the back of the engine, but I was unable to tell if coolant is leaking out of a freeze plug in the back or the head gasket in the back.
I brought the car to the mechanic. The mechanic fixed the front freeze plug. Compression test shows 190 accross the board with wiseco pistons, cometic head gasket. There is no oil mixed with the radiator fluid either. The mechanic that is working on the car told me that he cant tell if its leaking out of the headgasket or the rear freeze plug and the only way to tell would be to take the head off and check the head gasket. He also said since the coolant bubled up then it probably destroyed the head gasket. I heard pressurizing the coolant system would show if you have leaks. Why wouldnt the mechanic pressurize the coolant system and check for leaks? Thoughts? Ideas?
